7.6 update issues
I have installed the 7.6 update and it seems that the tethering issue is back again. Can you kindly check on this as it was working well on the 7.5 update? File transfer seems to be working. @plamen
what is the tethering issue?
USB Tethering doesn’t work, is the issue. What’s the best way fixing it?
USB tethering seems to no longer work on 7.6 update on my brax3 also.
7.6 1 JULY 2026 updated - USB tethering issue remains. NFC bug is working now though.
Mobile Data not working after Update to iode 7.6
I have updated my Brax3 to iode 7.6 but now my mobile data does not work. I recognize that I need to reconfigure something about mobile data. I am with USMobile, and I must confess that I was using iode 6.3 for over a year until this week because I heard so many stories of wifi and network failing after updates. My mobile data was working before the update, but I did not take a screen shot of that config page, and the seedvault backup did not manage to save those configs. I found this page from tmobile: https://www.t-mobile.com/support/devices/not-sold-by-t-mobile/byod-t-mobile-data-and-apn-settings and I was following the Android section, but I cannot get mobile data to work. I only have internet when wifi is available.
I noticed that the Tmobile page says I must enter these: “MCC: 310 / MNC: 260” but there are no fields displayed where I can enter those values. Please help.
Silly answer… Is the mobile data switch on under the sims profile under setting section? This has turned of during some upgrades…
Yes, I have turned mobile data on and off several times, I have restarted the phone several times. Other articles I found:
1
https://www.t-mobile.com/support/tutorials/device/oneplus/9-5g/topic/connections-amp-network/apn-and-data-settings
2
3
4
5
Ok. I found it. I followed this one - added new APN for epc.tmobile.com now that I am using iode 7.6 and Android 16 - and followed this one:
I still could not find a place to enter MMC and MNC, but I used
APN protocol IPv6
APM Roaming Protocol IPv4/IPv6
and then restarted the phone again, and now mobile data works. Thank you!
