Android tool : System Tracing
Hello,
I have received my Brax phone, but there is something missing: the android “system tracing”.
I can’t find it on the hidden “developer options*”.
And it is a must!
Indeed, it records lot of activities on your phone, helping you to investigate the behaviour of the phone, pointing out the potential activities of hackers for days.
Record files are recorded in perfeto-trace format, weighing up to 20 Go each.
For a forensic investigation, it helps a lot.
How comes I can’t find that option on the Brax3?
Is there any solution to corner mofos infiltrating your phone by recording the weird behaviours of your phone related to the infiltrated parasites?
Antivirus are useless to prevent some threats… Sometimes the best defense is the ability to spot their activity.
Anyone, an answer?
Regards.
What is android system tracing:
* to acces developper options:
Go to Settings > About Phone > Tap “Build Number7 times. You’ll see a message that says “You are now a developer.” Go back to “Settings” and you’ll find a new menu called “Developer Options”
