APN failure for chomp
Hey lads! Hope all is well, I recently discovered that the chomp messaging is struggling with my APN. It gives me a notification often to check and edit my msm settings and restart. I also found out that I cannot receive photos, send photos or even start groupchats :frowning: looking for any tips or advice, thank you
Chomp works fine for me on Mint/Tmobile and US Mobile/ATT.
What carrier are you on? You need to search the forums for that and change your APN yourself.
I switched to chomp hoping the sending pics would be corrected but not so. I’m on 7.9 sep24. Shows in sent message but never gets to destination. It worked on 7.8 so something changed…
Went back to the beginning and redid the APN… Works now. Cheers.
