Since no one else has piped in, I’ll try to answer. AOD probably refers to Always On Display. I would assume an AOD widget sets up what information is displayed on the phone when the screen is “off” but not actually off (personally I turn AOD off, I prefer extra battery vs seeing the weather and time by glancing at the phone when it’s out of arm’s reach).
Ah, makes sense. I’ll do the same. In fact, I’ll remove that from the widgets I use now.
Thanks.
Any idea if I can get emojis on the iode keyboard? I’m using Session Messaging with the wife and under settings I’m reading it say “physical alt key shows the emoji palette”. Can’t find that key. The menu looks to be the exact menu from the Brax3 settings so I think its not a Session keyboard.
Further down, under ”experimental” it says Android 15 under “Override emoji version”. The Brax3 comes with 15.
Press and hold the Enter/Return key, you’ll have two things pop up…don’t lift up and then select, rather slide your finger over to the one on the left (I think it looks kinda like an emoji…I’m still waiting on my Brax3 but rest of the family is on Pixels with iodeos and that’s what they have to do to get to emojis).
So I set the iodé blocker to none for the “default printer” and for the Epson app that the phone offered to download if I would select where from, i.e. Aurora Store.
I think the issue was trying to print from Standard Notes app. It kept saying currupted something or other and saving to PDF. And then there’d be nothing in the pdf.
Once I tried printing something from the browser it worked fine.
When I make a video screen larger the buttons to operate it are on the bottom of the phone screen. I’ve found that I have to tap almost a half inch below them and touching them directly has the same function as touching the video screen above them, I.e. the video player pauses and starts.
Yes Trebuchet is the launcher / iodéOS system. Try searching forum; it got discussed a couple of times in the early days so may cover what you are experiencing.
