BraX3 - Supported SD card
Just wanted to be sure I get the right SD card for the BraX3? Is a 1TB card too big? I was also having trouble with the generic music app, it was playing just 1 sec of each song, but some songs played through? I read in the comments to download VLC. Trying that now. Seems to be ok so far.
It supports up to 512GB but it is recommended up to 256GB, the cards are designated by classes of storage and speed and you probably have to avoid the most modern ones, you can find some specifications on Mediatek’s website concerning the SoC but the peripherals may not support the maxima claimed by Mediatek.
Better go to a shop and test some cards.
