Can I be issued with another IMEI number for my Brax3?
I Now have a National ban on my Brax3 phone that Vodafone Australia will not lift. If I never Trusted Vodafone in the first place my Brax3 wouldn’t be banned because the other 2 Carriers say brax3 has no compatibility issues on Australian networks. If you can’t issue me with a new IMEI could you tell me how brax3 IMEIs are generated like are there 100 spare numbers for every IMEI used etc.
The esim should have a different imei number if it operates like a dual sim phone. Just get a boost esim maybe?
Or
Vodafone won’t lift the ban because they are using it as CYA for their fault in the two Samsung 000 failures. They are using the AMTA Stolen Device block list for a purpose it was never intended for. Reason enough I would think to change to one of the others who accept the BraX3 is compatible. You will need to hassle them but others have reported getting the block lifted.
I have considered swapping the 2 IMEI numbers around instead but the 2 number are only 8 numbers apart and therefore the might figure this move out.
I rang boost and the guy said he was the man but he can’t unblock it, When I told him that if he can’t unblock it then he isn’t the man. He then hung up on me
I dont really know the answer. But maybe it’d work getting a Telstra/ optus esim and trying it. Vodafone is completely out of the equation, so have no business with regards to other the imei
I’m not sure specifically the topic name but look up Brax2 network compatibility bypass procedure, or some iteration of this. In the US it is legal to change the phones identity with the manufacturers permission. Brax put out how to do it with his permission. I did this years ago and used the IMEI of a phone I already owned but was not using, that was acceptable to the network providers. So my phone was a Brax2 it identified as the other phone. Brax also offered an IMEI but I chose my other phone. Not sure what the laws are in AU for this so you should look that up before you try
Same law in AU. As long as operating with the permission of tje manufacturer
Found it. Go to brax.me online.
Go to FAQ
Find thread titled, " (IEMI) To Flash the IMEI of Brax2 Phone "
This is permitted for Brax2 phones. Try messaging Brax to get permission for Brax3. I’m sure he will be sympathetic to your problem.
Changing the IMEI is a short term solution for one user.
A standard BraX3 appears to be compliant with Australian law, and is (still?) accepted to operate on the Telstra and Optus networks, provided it has not been used on Vodafone and got itself accidentally blocked.
The long term solution for everybody is for BraxTech and as many Australian users as possible to contact the
to 1) get the illegal blocks lifted from ex-Vodafone Brax devices,
and 2) stop Vodafone from abusing the Stolen Devices list.
