Complete Newbie, Help!
Hi I am a complete newbie when it comes to secure phones and laptops. Could someone please give guidance to some questions. First I have been on the Apple train since the first iPod and everything I have computer, iPad and phone all apple. However I would like to get my privacy back, how do I go about the transition. I have several contacts via WhatsApp and telegram. What is everyone doing with that transition? Im very simple only use tech for browsing and research and writing, and general photos, and file holdings like docs and such. Thank you
I was an iPhone user too, but I’ve been on a lot of privacy phones over the years which probably helps ease the transition. From my experience BraX3 is great. I love it!
If you’re using it as a privacy phone, as with all the others, you have to make compromises, but that said, with the BraX3, I haven’t had to make that many personally. If you like problem solving this can kind of be fun! I already tried to use a lot of non-mainstream apps and had habits for privacy on the iPhone (as much as possible). I helped others set up their BraX3 and they were a mix of iPhone only users and android users. I’d say everyone had the same learning curve, but the android users were more familiar with the interface even though they really hardly used settings for much. I’ve had to help a couple of times explaining how to do some things so just ask on here and lots of people will be glad to help answer. The cool thing is there’s usually more than one way to do something which is not my experience with mainstream phones.
I’ll mention some of the things I tell people who hadn’t used a privacy phone before. You generally have more control over your device so begin to think that way. If something is doing (or not doing something you want) you can more than likely change that. You are free now :slight_smile: Explore your phone settings & App settings - you can do a lot in there and it’s okay to play around with settings. Just remember what you’re doing so you can reverse it if you don’t like it.
Quick Settings Pulldown Panel
I also set up the other people’s phones so that the quick settings panel (that pull down panel when you swipe downward from the top of the phone) had all the mic access, location, bluetooth, internet, mobile data, vpn, security and privacy, and hotspot display first thing. That makes it more convenient for you so you can change settings faster. I tell people to keep the mic/location/bt/wifi off unless they need it. It’s something to get in the habit of doing. Turn the mic on for calls (video call apps) and video recording. The phone will remind you to unblock the mic if you get in incoming call which is nice! You also get prompted to turn on location when using certain apps. You can always decline these prompts if you want to keep them off.
Force Quit
If any app acts funny or doesn’t want to work. Go to settings > Apps > select the app and ā€œforce stopā€. Do this also if you want to stop an app running in the background. Also check to be sure you don’t need to update the app from which ever App Store you downloaded it from. And there are apps that can help you auto update so search around.
IODE APPS
There’s also a pre-installed iode app called ā€˜Updater’ which you need to check occasionally to get OS updates. The News app, that is also pre-installed, will let you know about the updates and tell you more about them. Once you update restart your phone.
Iode app is the one you want to check occasionally. The launch page of this app should be in the blue and say excellent. If you get yellow or red you need to click the button. Go to the app that is showing yellow or red and change it to reinforced.
APP STORES [F-Droid, Aurora, APKPURE)
So you now have two stores instead of one very locked down app store on the BraX3 Phone. These are pre installed (F-Droid & Aurora). You can download other stores post purchase (like APKPure). I would recommend you try to download from F-droid the most. F-Droid focuses on Free & Open Source Software (FOSS) and it insures the apps in it’s library are secure. It also doesn’t have dependencies on Play Services (so Google free). Then if you can’t find what you need there try Aurora. Aurora is a anonymous client for the Google Play Store. Never log into Aurora or you mind as well use the play store directly. Aurora doesn’t guarantee the apps are FOSS or secure, but it does show dependencies and trackers in the app descriptions. You can use the phone’s OS to block some of these dependencies if you want. So if it says ā€œNeeds Access to Contactsā€ you can just say no when it prompts you. You can’t do that in the apple App Store or the Google Play Store. Aurora does have dependencies on Play Services so you’ll utilize your pre-installed Micro-G service for the apps from Aurora if needed. In Aurora it will tell you if it can work without play services, but regardless Micro-G is pre-installed on BraX3 so you’re good. Micro-G spoofs play services.
With Aurora Store, it’s not always able to connect because the certificates get revoked so just go to the top corner in the app, where the gear is, and go to spoof manager and change phones and try again. Sometimes this doesn’t works so I recommend getting APKPure in those times where it doesn’t want to work. Or if you’re patient just try again later on. It will eventually work again. You’ll get weird errors on Aurora, but it’s nothing you did. Just close it and try again later (or change the spoof manger).
WHATSAPP
I don’t use WhatsApp, but I have heard there is an open source bridge between XMPP & Matrix and WhatsApp. I’ll let people who use it explain more. I’ve only heard about it. Two I’ve heard of are Slidge & mautrix for XMPP (decentralized), but Matrix is federated so has theirs listed on their own website. You’ll more than likely have to get the XMPP bridges from a GITHub repo I’d imagine, but I’m sure there’s instructions on how to do that from the respective bridge’s repo. (Or maybe others will chime in and explain how they do it more.)
TELEGRAM APP
And as for Telegram, you can get the forks of that off F-Droid & Aurora Store. I know of a few, maybe there are more? To get Forkgram and Mercurygram app go to the the F-droid App Store, and for Telegraph app go to the Aurora Store. Mercurygram is a fork of Telegram-FOSS that focuses on user privacy - it’s customizable so not exactly like the Telegram interface. Fork gets more updates from the main telegram app and is very much like the telegram app, but isn’t as secure as Mercury or Telegraph.
HELPER APPS
So you have choices. Of course you can also download the actual apps, but WhatsApp will scour your info - particularly contacts in its search for telemetry data. In the F-droid store if you search ā€œWhatsā€ it will pull up some solutions to WhatsApp going after your contacts and info (there are apps for that). This goes for any app. Search on the web for the solution you want and include the term FOSS in your search to get some ideas of app names then search those names in F-droid. Or try the name of the thing you want in F-Droid and sometimes people have named the app with that name in it so you know it works with or is an alternative to that official app.
(Side Note: If you ever want to know more about two apps just search in a browser ā€œ[name of app] vs [name of app]ā€ and you’ll more than likely get opinions about both and if you have AI Search it will give you a chart comparing them. And also search this forum - lots of users discuss what they use and why they like it.)
FORUM INFO
If you search in this forum there’s lots of people talking about different things like photos. Eventually users here will find all the best apps and share it on this forum. So read around and you’ll pick up a lot of cool tips and tricks!
Here’s one on Photos - Mycenius & others are looking into finding the best app for the camera to get the most out of it.
Hope that helps! Enjoy your phone and welcome to the community! :slight_smile:
