Hi Guys,
just wanted to ask if there will be an option to connect Wink to a car in order to display maps, use spotify, call? (similar to Android Auto or Apple Car Play).
Would it be possible via bluetooth and/or usb-c?
thanks ![]()
Hi Guys,
thanks ![]()
Hi there, Apple Car Play won’t work (since it’s iOS product), but you will be able to make Android Auto work. To enable it you will need to install some google apps and login (google app, google maps, google speech service, android auto). This will be sharing data with google (specifically location data), but if you use a dummy google account, you are more private than the standard android experience, since these apps won’t be installed as system apps with constant access to telemetry, but instead will only get location data when you turn then on.
Without android auto, you will be able to connect your Brax Wink via bluetooth, and play music / make calls, etc. (but without the android auto navigation feature).
This is how the BraX3 also works currently. We will be looking into possibly improving this experience.
thank you ![]()
