Error message and random restarts
I have to report, @plamen, that since I upgraded to 7.2 my phone has on several occasions gone through a totally random restart for no apparent reason. On the last two occasions it has given the error message that other people have spoken about where it says “Your device is corrupt. It cannot be trusted and may not work properly etc..” Could this be a bug in the 7.2 update or is it being caused by something else? George replied that he believes it is a hardware issue - is that right? I managed to get it going again by repeatedly holding down the power key but with the second occasion being more difficult than the first, it’s beginning to feel like it will only be a matter of time before it refuses to start at all. What is the latest news about this fault please and is there a fix to repair it? Many thanks.
Since writing this post the phone has repeated this fault again, this time randomly shutting down overnight so I missed my alarm call! Error message showing again and it took many attempts to get it going again. Once up and running everything seems to work fine but the random shutdowns with accompanying error message are clearly increasing in frequency. Has the cause of this problem been identified please? I am reluctant to ship it back to the US (I’m in the UK) if it turns out to be a bug that can be fixed with an update but if it IS a hardware issue I will have to return it. I’m assuming that you don’t have stock sitting on the shelf to do a quick replacement(?) so will I be waiting ages for the next batch to arrive? How long will that be? Please advise what is the latest on this issue. Many thanks.
You do the reference in text like this @plamen
Thanks George, is the edit I have done above correct?
Yes, it’s OK.
