Focus on .6x mode not working
Hello on my Brax 3 the 0.6 mode is not not in focus either with the stock app or the Open Camera. Is it a software or hardware defect?
Thanks.
It only works in micro mode on my Brax, it will not focus beyond an inch or two from the lens surface (manually moving phone back and forth) and it has the same visual perspective as the top camera. Kind of worthless unless you need to take extreme closeups…
Edit: I went back and looked at the official spec sheet on Braxtech.net and their are supposed to be 2 cameras; 1 is a 50 Megapixel and the 2nd is a 2 Megapixel “Telephoto” camera.
I guess there are no “ultra wide” cameras on the Brax 3. I am also guessing the “telephoto” designation was mislabled/ confused with micro focusing. Might be a cultural/translation issue, as the phone is made in China.
Either way, there is no “utlra wide” camera on the Brax 3…
thanks @Igor_Shotsky
