Super interested in the Wink phone. I would like to know if I can use Tangem wallet and Debit card apps from the play store
Tangem Wallet is supported. The debit card app will depend on whether the app developer has enabled support outside of a google certified device. Brax Wink will not be google certified, as it’s a completely deGoogled Android.
Thank you for confirming Tangem Wallet support. Just to clarify: does this include scanning physical Tangem cards over NFC and signing outgoing transactions on Wink, without Google Play Services or microG? Has that workflow been tested on a Wink device?
It is not tested on a Wink device since the OS for it is not developed yet, but it will be working as expected, since there is no dependency on google play services.
