Home web cams use?
visiting this topic again, for US users.
can one use home security/web cams apps safely on the brax3? I tried going through a web browser but the one I have doesn’t allow that, can only use their app. I am using the blink cameras.
Have you tried setting up a VPN that directly connects to your home network? Then using the Blink app will be more secure. Of course you would need to remove internet access of your cameras and make them only visible to the home network.
no I haven’t tried setting up a VPN on my home network, wouldn’t know where to start. If I did all this would I still be able to access the camera’s remotely? or only when connected to the home wifi?
You will be able to conenct to your cameras with no issue. My cameras are not visible from the internet, only via the home network. I use the manufacturers app to connect to the cameras at home and via openvpn, remotely. This way I have more secure access home and remote. I travelled to the carribean and via wifi connection, using the vpn, I’m able to look at all cameras and get relevant notifications. Not sure what you run as a firewall/router, but most of them allow you to configure a vpn connection. Check you manual or support to get more information on the setup. The key to remember is that the cameras cannot be accessed directly form the internet.
I don’t understand how you can access remotely without using the internet? my home wife signal is only so strong, I can’t access my home wifi when I’m 2000mi away?
You use the vpn to connect. The VPN allows for a sercure connection to your home network. Your router/firewall should have instructions on how to set up a VPN connection for remote connection. Also, you can contact your router/firewall support for help on configuring a VPN for remote connection. The good part is, once set up you will be able to connect to your cameras as long as your home Internet is up.
There are many levels of privacy and security that you have to think about here. Most cameras are not trustworthy to have internet access. It is best to cut them off from accessing the internet and having them connect to a local solution like ZoneMinder. Once you setup ZoneMinder or something similar you can view and record from them there. ZoneMinder can be setup to be exposed to the net so you can login remotely OR accessed by VPN.
This is not a simple solution which is why most people don’t do it. Another solution as others have talked about below is using a VPN to access the cameras. I would suggest cutting those cams off from public internet as they may be phoning home. Don’t use their apps either. Make sure that they are accessible by Web or RSTP and do so by VPN.
All you need to do is install the “Blink app” on any device and use it, you dont need to do anything else. I myself would skip everything above and just use the apps, you will be fine. :grinning_face: I am not saying anything is wrong, just overkill for many IMO.
I would not use Blink or Ring myself, but I can access all my 20 or so :rofl: security cameras thru their different camera apps. I have 4 of the different apps on my phones.
I use Tapo, Eufy, UBox, Femii and some are duplicate solar backups to the main ones. So if anything happens power wise, the solar ones will still work. I think some of the main ones are also 4g so will work when no power or internet.
so you are saying that signing in to my Blink app on this phone will not risk my phone getting googled? which is the whole purpose of the google free brax 3 phone right?
Personally, I would not use any of those. If you care about privacy those should not be on your list of things to ever use. If you already have them I would devise a plan to replace them with something under your control.
The problem is not whether you will get Googled by using their app.
The problem is where the signal from the camera goes. If it goes to the company’s servers, then Law Enforcement Authorities may view it without your knowledge or permission. If it goes anywhere on the internet, then you must ensure your home router is securely setup. If you want to view it from anywhere via the internet then standard security advice is to use a private VPN that you set up yourself. Your home router, or the Camera App may (or not) have this facility. But, if the cameras are required by the vendor to connect to their servers, then you are in their hands.
