To enable notifications for the Baristas On Tap app on Android, navigate to your device’s Settings, then select Apps & notifications (or Apps) and locate Baristas On Tap. Tap on Notifications and toggle the switch for Allow notifications (or Show notifications) to the on position.
Hi there. Notifications on the BraX3 are enabled via MicroG (it replaces Google push notification system).
Can you confirm if you are receiving notifications from other third party apps (apps not installed by default on the device)?
To troubleshoot notification issues, go to Settings > System MicroG settings > Cloud Messaging.
See if it’s enabled and see if the Baristas on Tap app is there and is registered. If not - enable it.
If cloud messaging is enabled but you don’t receive any notification from third party apps - then the issue is on MicroG level. In that case, go to Settings > Apps. Once you find MicroG, clear it’s storage data.
If cloud messaging is enabled and you get notifications on other apps, except Baristas on Tap, then something is restricting it. In this case try to play with your MIcroG settings (device attestation, play store servives, google device registration). If nothing works, then the app is probably incompatible with MicroG (which is very rare but possible).
After I have done everything that was advised, all I had to do was, to unistall and install again the app, now it works
One more question? I get a sound notifications, it won’t show up, after I scroll down, then, I can see the notification, that is better then before for sure
Is it possible to have this notification pop up on the screen even while doing other things? Instead to have to scroll down the notifications page?
I didn’t fully switch on brax 3 from my iPhone yet, still trying to understand how Brax 3 works, Baristas on tap its the only app I really need notifications to work, I need it for work, at the moment I get a sound, and it shows up only when I check the notifications window, what I was wondering was, if, there was a way to have a notification pop up showing up when I’m using Internet or other thing.
The expected behavior is for a pop up notification to appear (on the top). Can you clarify if you only have issue with that particular app or the issue is with other apps too? That can help us understand if the potential issue is app related.
Thanks for the message and the help, trying to activate telegram and WhatsApp, to check for the notifications issue with baristas on tap but failed to do it, once I can get access on that two apps I can compare, telegram send a sms that never arrived, while WhatsApp I made a mistake and need to wait 24 hours.
