How to share Wireguard tunnel with WIFI hotspot clients
Hi together !
I’m another happy BraX3 owner now :slight_smile: … wondering how sharing a Wireguard-tunnel with WIFI hotspot clients can be achieved, since there seems to be no direct option/setting for this.
Does anyone have a working solution for this ?
Many thanks !! :slight_smile:
Hey there!
Glad you’re enjoying your BraX3.
You can toggle “Use VPN for connected devices” from the Hotspot & tethering settings of your BraX3 (Settings > Network & internet > Hotspot & tethering).
Hey wonderful, thank you so much for this quick response !!
Why didn’t I found this myself ? Sorry :-/
However, after some trying out … I’m facing another problem here:
Some different conditions/scenarios:
(Where for all scenarios the condition: “Hotspot active and client is connected” is true)
Scenario 1
  • “Use VPN for connected devices” = OFF
  • Wireguard tunnel = DOWN
    => The client has internet access, BraX3 has access to the internet
Scenario 2
  • “Use VPN for connected devices” = ON
Scenario 3
  • Wireguard tunnel = UP
    => The client has internet access and can not reach the remote LAN, BraX3 has access to the internet AND to the LAN behind the VPN
    (Makes sense)
Scenario 4
    => The client can reach the remote LAN but NO internet access, BraX3 has access to the internet and to the LAN behind the VPN
Important: The wireguard tunnel is a tunnel to a specific remote LAN not to the internet.
However, when the “Allowed IPs” of the wireguard tunnel is changed from the “remote LAN only” to “0.0.0.0/0” (to anywhere / to the internet), the client connected to the BraX3 hotspot can not reach the internet, only the remote LAN … and the BraX3 itself as well can reach the remote LAN but not the internet. Which is logical, because the tunnel is designed only to reach the specific remote LAN.
Since the wireguard tunnel (server side) is “designed” to only give access to the remote LAN, setting “Allowed IPs” (in the wireguard client settings) to “0.0.0.0/0” which tells BraX3 to route ALL traffic through the tunnel, has the effect that BraX3 … and its hotspot clients are then not able to reach the internet, only the remote LAN.
(Conclusion)
Which means, the issue here seems to be, that “Use VPN for connected devices” always assumes that the tunnel is an intended “0.0.0.0/0” tunnel ( => which results in routing ALL traffic of the hotspot clients through the VPN tunnel), instead of routing the traffic according to the “Allowed IPs” parameter. (This parameter is not being respected by the “Use VPN for connected devices” to define the routing table.)
What do you think ?
My best regards & big thanks !! :slight_smile:
Hi there,
Your conclusion is right. “Use VPN for connected devices” doesn’t use the tunnel’s Allowed IPs to decide where hotspot traffic goes. When the toggle is on and a VPN is up, Android sends all forwarded traffic from hotspot clients to the VPN interface. Apps on the phone itself still get split tunnelling, which is why the BraX3 reaches both the internet and the remote LAN in scenario 4 but your clients only reach the LAN. This comes from how Android handles VPN with tethering, not from your WireGuard config. Tethered traffic simply doesn’t get split tunnelling.
Until that changes, here are some ways around it:
  • Let the server route internet traffic. If you can change the WireGuard server, enable forwarding and NAT/masquerade from the tunnel out to its WAN, then set Allowed IPs to 0.0.0.0/0 on the BraX3. Everything goes through the tunnel, so clients get both the internet and the remote LAN. The cost is that all hotspot traffic leaves through your remote site’s connection.
  • Run WireGuard on the clients. If the clients are laptops or tablets, give each one its own peer with the LAN-only Allowed IPs, and leave “Use VPN for connected devices” off on the BraX3. They keep normal internet through the hotspot and split tunnelling works on each device.
  • Switch the toggle depending on what you need. Off when clients need internet, on when they need the LAN. Not ideal, but it works with no server changes.
