Is Swiss Provider Sunrise/Yallo compatible with brax3?
I wanted to ask if the Swiss provider Sunrise/Yallo is compatible with Brax3. I tried two of their SIM cards and couldn’t make any calls or send any text messages. However, the cards work with another phone.
Possibly you have to manually configure the APN(s) for the SIMs once installed.
That usually solves it.
If not, try contacting your carrier to see if they can find any issue on their end.
