Can’t fix this till I fix my main issue
Hi there.
Have you tried contacting your carrier to see if there is an issue on their end? We’d recommend that as the first step in trying to fix connectivity issues.
A few things you can also try:
- Check if the APN is correctly set up.
- Try switching airplane mode on and then off
- Reboot the device
- Eject the SIM and then insert back (if physical) or uninstall and then install back the service (if eSIM)
You can check our FAQ article on troubleshooting connectivity related issues: BraX3 Frequent Questions and Troubleshooting
How to contact the carrier? Is there a 800 number? How to determine if the APN is correct please?
That will depend on your carrier. Try contacting them through their support channel. Often APN information is made public.
Once you find out what is the correct APN, you can check / change your APN from settings > Network & internet > SIMs > [Your sim] > Access Point Name
Did all of that. Many times. I think my phone is hacked by t mobile scammers. Well im hoping I won’t be leaving T mobile bc I’ve been dealing with a major scam with them. Now every time I call t mobile it seems like im still talking to scammers. Always when I call their numbers 611 or 800s, I always get disconnected over n over n I end up talking to the guys that sound exactly like the scammers in their accent n the things they say. So I have a BRAX 3 but I think they’ve HACKED MY PHONE.. I don’t get regular calls dropped. When my call drops with them I get an error saying something about the SERVER lost connection. (?) I lost connection when they finally said after an hour plus that I’m being transferred to a Supervisor, n the call was dropped, a few minutes later a guy sounding like a Scammer calls me back saying he’s the Supervisor. Costs they expect me to pay is almost $6000, I was out $370. My normal bill is supposed to be only $82./mo
Use this for Tmobile as same thing as Mint.
https://www.mintmobile.com/help/how-to-configure-android-settings/
