Live Stream Anomaly
I was viewing a live stream yesterday and noticed that the phone froze for about 10 seconds and then started again for a few minutes and repeated the freeze continually. I have not noticed this when viewing videos. Interestingly, all access to the entire phone stops during the freeze. Anyone experienced this issue and if so, was there a settings solution? Thanks
Hello, can you share which app you’ve used for the livestream? And have you noticed the issue with any other app viewing video / stream?
Also, what OS version are you currently on?
I’m using the iode Browser. I have not tried any other apps to live stream. Currently on 7.6-20260610-brax3. I get the same reaction using WiFi or ethernet connection. Almost like some kind of buffer overflow type of issue affecting the entire phone. Thanks.
Which site are you streaming from through the iode browser? We will try to reproduce the exact environment.
I went to Watch & Listen to The Alex Jones Show and War Room Live 24/7 and watch the live stream. However, yesterday I upgraded to 7.7 and the problem seems to be corrected.
[quote=“raajah, post:5, topic:4782”]
