Problem: I cannot find where to change the Low Battery sound, or its volume.
BraX3, iodeOS 7.8-20260930-brax3, (and all previous back to 7.5?) when the battery charge level drops to 20% a notification sound plays and on screen I am invited to turn on Battery Saver. I understand the 20%, and from a battery health standpoint the notification should be obvious and upfront. Are we stuck with being jolted awake with this notification?
There is no way to control the sound level on it, but you can disable the sound and enable vibration.
You can do that by following these steps:
- Open Settings → Apps → See all apps.
- Tap ⋮ → Show system.
- Select System UI → Notifications → Battery.
- Tap the Battery category name, rather than its toggle.
- Keep notifications enabled, but set Sound → None.
Thank you Sir. There’s an Alladin’s Cave in those “System Apps”
I’ve changed the sound to my normal* Notification sound. Now, to wait and hear what happens next time I hit 20%.
* I used to work with musicians, so I chose a sound from the Huawei collection, distinctive, discrete, unmistakable (to me). Name: Shaula, a single shake of a maraca 400 ms with 400 ms fadeout.
