MMS/Picture Messaging FIXED on Brax 3 - Brax SIM Unlisted
If you’re on the Brax SIM Unlisted and can’t send pictures via text (MMS), here’s the fix:
The APN settings need to be World Mobile’s, not T-Mobile’s. Even though World Mobile runs on T-Mobile’s network, the APN is different.
Go to: Settings > Network & internet > SIMs > Access Point Names
Delete any existing APN, then tap + and add:
APN:mobiledata
Leave everything else blank
Save
Make sure the radio button is selected for this APN
Restart your phone
That’s it. MMS should work for both individual and group messages.
Why this matters: I wasted hours trying T-Mobile APN settings (fast.t-mobile.com, pwg, wholesale) with various MMSC URLs. None of them worked for MMS even though data and SMS worked fine. The issue is that Brax SIM Unlisted uses World Mobile’s infrastructure, and their APN is simply mobiledata.
Also make sure your using Aurora store messaging app (QKSMS):
Settings > MMS > “Send group messages as MMS” is ON
Settings > MMS > “Send long messages as MMS” is ON
Settings > MMS > “Resize sent MMS images” set to 200KB or 300KB
You can get QKSMS messaging app at the Aurora store. After you set it as your default may have to search for it and pin it to home page. Hope this saves someone the hours of troubleshooting I went through!
Thank You! I use AT&T. I did nothing with the APN, but your other settings changes solved my problem - group messages MMS on, long messages MMS on, and I tried all the size limitation settings. It worked for my phone up to 600k. Useable.
MMS doesn’t even show up in search on my Brax 3. I need technical support. I tried all the suggestions on here and still can’t text on first attempt and no picture sending at all .
You’re not alone. I switched to QUIK and it didn’t help much. It’s a Google and Apple SMS (and related tech) world, so sorry.
I used Signal on my Brax3, no problem.
I switched my main driver to a Pixel 9 running GOS and that OS’ default texting app works much better (as long as you’re on the Owner account). But upstream AOSP seems to not have all the glitches worked out between the different profiles and as a result, I also primarily use Signal on that in the user1 profile (my main daily driver profile).
Hopefully something FOSS comes along soon that works well enough with the stock Android and iOS texting apps.
No, I transferred number I had used with previous carrier, so i assumed i would not be compleatly anonymous. If its a brand new number, i might just use a gift card, if i had one.
Here are the settings that worked for me on my Brax3. I can send and receive messages and pictures. This is if you are using the Braxsim. I put Carrier Send Limit on 300KB.
Open the Access Point Names or APNs menu.
In Settings, check under Wireless & Networks.
Select Mobile network.
Select Access Point Names.
Choose the T-Mobile APN if one is available. If not, select the (+) and a new APN opens up.
Verify and update the following settings for the Data APN.
