Has anyone else had this problem of icons appearing only in monochrome?
Are you in reading mode? It was mentioned in the thread where someone wants to make iodéOS look like Graphene - there is a reading mode setting that will make virtully everything monochrome…
Hi Mycenius, No I am not in reading mode. It must be something I have done in the settings. I say monochrome but, the icons are green on a black background. The remainder of the screen is blue, fading from the bottom of the screen to the top.
Regards
@Wingman106 have you tried looking for Settings → scroll to bottom → Accessibility → Colours and gestures → Colour correction.
There try to play with setting.
You can look in 1) Settings → Display → Colour block; 2) Settings → Wallpaper and style → Home screen → Themed icons (you can try other settings there too, maybe something works).
I have looked at the settings to no avail. When I slide the screen up I notice the icons are normal; i.e. coloured.
Thanks for your help anyway.
Think of Themed Icons. Wallpaper and style, Home screen, look to the bottom of the screen and turn off Themed Icons. Your icons will now be in full colour. Hope this helps someone else.
Regards to all
Philip
