I tried to open a return through the customer portal and was unsuccessful.
In a nutshell, I cannot access any browser on the phone despite a strong internet connection and all other troubleshooting. The default browser does not work either. This phone is of no use to me. It is defective and needs returned.
Hi there, what browser applications have you tried? And what happens when you try to use the default browser and other apps - you can’t open the apps, pages do not load or you’re getting some errors?
Also, how do you verify that you have a strong internet connection, and how strong is it? Try installing an app such as speed test by Ookla (available via aurora) to test the speed you’re getting.
All browser applications have been tried. apps do not open. pages do not load. no other browsing problems on any machine or device except for the Brax phone. This is the second time replying. Responses are not posting. As previously requested, we need the address to ship the phone back to. Thank you for your prompt attention to this matter.
You can submit a return via the customer portal at my.braxtech.net . If your return due to change of mind window has expired by a few days, we can extend it.
If you decide yo keep your BraX3, we’d suggest that you do a factory reset on the device, make sure you are connected successfully to the internet.
