Please provide ls -la when in that directory
UPDATE: re-checked from scratch, maybe you are missing the executable bit? Do this: sudo chmod +x SPFlashToolV6 then it should be able to execute.
$ls -la
total 11168
drwx------ 1 guest guest     516 Apr 16  2023  .
drwxr-xr-x 1 guest guest     296 Aug  4 18:35  ..
-rw-r–r-- 1 guest guest      54 Jul  4  2022  99-ttyacms.rules
-rw-r–r-- 1 guest guest   12545 Jul  4  2022  console_mode.xsd
-rw-r–r-- 1 guest guest     378 Apr 16  2023  Credits.txt
drwx------ 1 guest guest      56 Apr 14  2023  Driver
-rw-r–r-- 1 guest guest     167 Jan 24  2018 ‘How to Use.url’
drwx------ 1 guest guest     902 Jul  4  2022  lib
-rw-r–r-- 1 guest guest 2203664 Jul  4  2022  libflash.1.0.0.so
-rw-r–r-- 1 guest guest  383528 Jul  4  2022  libimagechecker.1.0.0.so
-rw-r–r-- 1 guest guest 4882379 Jul  4  2022  libsla_challenge.so
-rw-r–r-- 1 guest guest      63 Jul  4  2022  modemmanagercmd.sh
-rw-r–r-- 1 guest guest     139 Feb 23  2020 ‘Official Website.url’
-rw-r–r-- 1 guest guest     464 Jul  4  2022  option.ini
drwx------ 1 guest guest      18 Jul  4  2022  plugins
-rw-r–r-- 1 guest guest    3013 Jul  4  2022  readback_ui_bak.xsd
-rw-r–r-- 1 guest guest    1057 Jul  4  2022  read_efuse.xml
-rw-r–r-- 1 guest guest 3901232 Jul  4  2022  SPFlashToolV6
-rw-r–r-- 1 guest guest     272 Jul  4  2022  SPFlashToolV6.sh
-rw-r–r-- 1 guest guest    1059 Jul  4  2022  write_efuse.xml
Just did sudo chmod +x SPFlashToolV6 and it now works.
Thanks.
Just edited the guide I made above to clarify this for Linux. Thanks for your persistence!
Now when I follow the instruction Download-XML, navigate to the brax3-user/download_agent/flash.xml file. The file is not listed but it is on my desktop.
OK, I think I have sussed it.
You will have to rummage around in that clunky file explorer when clicking “choose” since you are running as root you will need to manually navigate to your user’s desktop folder.
Found it and running it as i type.
Seems to have finished but a box popped up with error message.
Do i now unplug phone from computer and turn on to reboot?
Yup, that all matches my experience. Let’s see if it worked!
Well, it basically factory reset my phone.
latest update is on it but won’t know if OTA is fixed until next release.
I have now lost the beta OTA updater.
When I download the apk and try and extract the file, I get the message Could not open “UpdaterBetaIode6v2.apk”
Archive type not supported.
That is correct, it gets reset with a system upgrade. The newest 20250803 release is now available as “stable” meaning you don’t need the beta updater to find it. Just refresh in updater, then download and install.
(for another time if you want to try another beta release, you do not “extract” the .apk, you just directly select this .apk and install on the phone.)
Ok.
Thanks for the help
Well, last comment: the full image you just installed is the same date. So I am not certain if the updater app will list it for you. But now that you are on this image, cut over to the wifi threads to report on if it solves your wifi connection issues!
I am one of the lucky ones, in that the phone connects to either of my home routers.
Could you please update the procedures/link to the latest files so that I can find the “flash.xml” file? When I extract the .zip file I do not get the “/brax3-user” directory.
