What apps are people using to stream podcasts which are generally safe and not intrusive?
I use AntennaPod
thanks guardian. i will try. appreciate your feedback.
Antennapod is really great and if you use nextcloud you can sync your podcasts and playback to it among different devices. Kasts on GNU/Linux syncs that way.
thank you greengenie. interesting that you can use nextcloud to sync. thanks!
Escapepod is another easy one to use.
thanks, i will check it out!
