Hello, for as long as I’ve had my brax3 I cannot send or receive photos, nor can I start groupchats. I’ve been getting this notifcation since I started using chomp, please let me know if theres any way I can fix this, thank you.
Hello,
This is a common issue reported with BraX3. You can check this advise: Text and MMS not working. Sim issue? - #33 by george
Installing QUIK SMS (available in f droid) works as a workaround for most customers. Sometimes issue is related to a misconfigured APN. It’s also worth to verify it with your carrier.
Hi there! Thank you for the tips. I tried all three and still nothing works
Did you try reaching out to T-Mobile support and ask if they see any issue in the backend? We recommend this as the first troubleshooting step usually with carrier related issues.
Tmobile is the same as Mint and I use Mint with these settings and mine works.
https://www.mintmobile.com/help/how-to-configure-android-settings/
I use Chomp too, works fine and one of the best I think.
I have great news! After battling boost mobile for this phone, I finially just signed up for mint and everything runs smoothly. For whatever reason, when I tried switching my old sim onto here, it was having the worst time.
