I’ve noticed for a couple weeks now that when my phone is charging at night that it reboots. I see no error and only know because it needs an unlock code rather than fingerprint. I am running 7.1-20251227-brax3 and no apps from Google play.
I was using this keyboard that kept crashing so I uninstalled it:
Now I have been using the default HeliBoard for a couple days but the phone reboots every night. Nothing else crashes. Any ideas?
There is a “Bug report shortcut” further down but I think you don’t need to enable it.
Open the file manager and hit the 3 lines to see the storage locations, you’ll see a bug report option, it’s a folder with text files which disappears when you exit developer mode.
Enable that option and hold the power button for the menu to appear and tap the bug report button.
Thanks-now enabled after it happened again while I was awake. The whole screen gets black and white characters for a couple seconds and then it reboots.
That puts the uptime for today at 13 hours. Mayhe that’s everyday now?
This is a hard crash, something kills the phone, if you don’t see anything in the report you can also connect the device to a PC with Android Studio through USB or WiFi debugging and let the computer capture the LogCat to see at what point it crashes.
the report files are named by date, open anyone that was logging when a reboot happened, they are just text files, towards the end of the files you would be able to see what triggered the crash, you may not see an error if the log stops but you will see what process was called last
I remember those crashes from Pinephone where the screen becomes black and white and fades out
On Android Studio you enable the debugging mode and connect the phone to the PC, then you have to accept on the screen the connection, choose Brax3 in Studio and then press the cat-head bottom left, you’ll see messages in a text box, you can read them after the crash to see what happened if it was able to log it else check again what the phone was trying to do
I had 2 random reboots lately while using the device.
The Bug Report is not so much useful because it’s generated on the spot for whatever has happened recently.
The only way is the USB or WiFi debugging. For me it’s difficult because I turn off the device and the WiFi and probably that was the reason I hadn’t noticed it.
In order to not lose calls you could remove the screen lock and the SIM PIN at night.
If you use USB debugging set it to stop charging at 80% to avoid destroying the battery.
it’s some condition that is fulfilled in specific moments, it could be related to a hardware fault or some other software bug, since I noticed it recently it could be related with 7.1, it can only be assessed if the system starts becoming unusable due to spontaneous reboots
It just randomly rebooted 20 minutes ago-the screen was off and just acting as a hot spot. When I woke it up it rebooted. It didn’t write a new bug report file, so now I’ll get it hooked up to a computer running Android Studio and then debug by USB.
The bug report works only the moment you press the button, it collects and stops, the debugging logs continuously, I use it when developing apps and it has a very rich output
