I was comparing the BraX3 to the phone my carrier gave me for free when they turned the 3G signal off.
It’s as close to identical as it can be without saying it’s identical.
The CPU, the size of the screen, the dpi of the screen, the battery.
The phone in question is a Moto g04 with dual physical SIM support. Last time I looked I could get one for £30. Ill just leave this here.
romluk
22
@Mycenius
Did you disable the ID tracking in OsmAnd settings?
With OsmAnd a unique installation ID is sent with every Map download.
y199jas
23
Looks like the Brax3 has a better CPU to me.
Oh, can’t recall if I saw that or not. Will check!
No I hadn’t! Have now, thanks!
A76 over A75 . . . . A slightly newer revision of the same CPU.
