This morning I saw that the release for Iode’ 7.9 is here! I already upgraded 1 of my BraX3 phones with it and had no problems! ![]()
It’s still Android 16. When do we get Android 17?? ![]()
Yes, I updated to 7.9 yesterday and whilst it works great i am disappointed that it has wiped access to previous versions. I have always left at least one previous (working version) prior to running an update. Just in case there is an issue and I need to roll back.
Why this change. I see it a negative move, certainly not an improvement.
Could you clarify what do you mean by leaving a previous version? You can roll back via spflash update, always. Here is the repository with OS builds: Brax Technologies Downloads Platform
OK thanks for that link, that is useful to know.
What i had previously on the phone update/version page was a list of previous installed downloads. It was there that i selected and removed the older versions once beyond the previous 1 or 2.
And when you’ve done the update to 7.9, do the following (instructions are for 7.8, I haven’t updated yet, something might have changed)
Settings > Security and privacy > More security and privacy > Encryption & credentials > Trusted credentials >
Scroll down to eMudhra, there are four certificates which must be disabled.
For further details search the cybersecurity blogs, eMudhra made some very poor choices of seed for the encryption in their certificates
There seems to be some issues with the updates for some. This 3 day old BraX3 probably would do an update if the updater is pushed, yes? There are a few problems with the use of the phone now and updating seems like an avenue to more problems esp. since the eMudhra talk here is a foreign language to me. To update or no? Will it cause more frustration or correct the no internet from eSim and volume problems? Thanks for writing
