Hi Brax Wink
Will there be a detailed instruction on how to side load app on ZERO mode?
Hi Brax Wink
We can share, yes. It will be similar to the Android sideloading experience - download an APK on your device and install locally. As long as the permission to sideload apps is enabled, the app will be installed.
Can u confirm so far WhatsApp will definitely be avail
Be for AKP file format to side load on zero mode?and be continually supported by WhatsApp updated ?
And with Tangerine support saying pending on web page but I checked the 4g lTE and 5G band are all p n the list ?
What sort of map is it on the default app cow, with the phone?google or ?
Yes, Whatsapp will be supported.
Based on the public documentation, seems that Tangerine is using Telstra network. If accurate, then the Brax Wink will work on it.
We will have our own Map application on the Brax Wink. The app will be open sourced as other apps we are developing. You can replace it with a different map app (through the app store in omni mode or through sideloading in zero mode)
Just want to give some good feedback here. This is awesome to hear! I have a brax3. the privacy map apps on it are not the best when trying to search for things like “breakfast tacos” or “coffee shops” “hardware store” or “car wash” ect. just practical stuff. But I don’t want to be downloading google maps. its so temping. But, I just don’t trust them suckers. I have downloaded waze, but I often wonder what I have compromised by doing so. So, it’s good to know you guys are working on something I can assume get me around basic work travel when I go to new cities to find a decent restaurants, hotels, ect. and know that all I’m looking at and doing is not being tracked
