I have iode 6.7 but when using updater to try install latest iode it does not complete
Additionally I have never been able to make wireless connection with a router so I’m thinking maybe by updating the iode that this may also be solved any advice
what router and version of software is it running? It might be that the wireless security is blocking you from connecting. Have you checked the settings on the router and your phone to make sure they match?
The router has been there for couple years and lots of phones have connected to it without any adjustments. My brax settings are detect automatically , proxy none , IP settings use dhcp, privacy use device Mac, send device name to
>privacy use device Mac<
Is this a filter be mac address?
Just to test turn off the use of any filtering, and password requirement and see if it connects.
If so turn on the security features one by one, testing each option.
