I find it fascinating to use an open-source Raspberry Pi (RPI) to manage my entire home network. I am a Qubes OS user, and I had sys-whonix torifying all my data before it gets to the network.
Now I could add all my other home devices that are not compatible with Qubes OS, allowing data to run through an external device, the BytzVPN on a open source Raspberry Pi, which acts like a sys-net + sys-vpn, right?
Do you see it the same way?
Additionally, If I understand correctly, the BytzVPN also sends the VPN-encrypted data to TOR in the cloud, so it will additionally act as an alternative to sys-whonix? (Data encrylted by VPN then twice encrypted by TOR)?
