New to android, none the less degoogled phone’s. Coming from Apple. What app can i use from Aurora store to prevent calls from people not on my contacts list comkng through? Thank you for the feedback
Go into your dialer, Settings-Blocked Numers. Option to block unknowns.
No app required.
We used to use Carrion for spam call blocking; but it is no longer maintained and is having DB d/l issues.
We are now looking at GitHub - aj3423/SpamBlocker: Android Call/SMS blocker.
Its far more comlpicated; but has more config options. So, this may be helpful.
Thank you all for the feedback
I ended up putting my phone on “do not disturb” from 7am-9pm with only contacts coming through (only 4 people have my carrier number). This has worked great.
