BLUETOOTH connection HELP needed
Brax3 Refuses to communicate with Sony WH-CH700N headphones also refuses to connect to my Apple ear buds - is there any work arounds? - running iode OS
Can’t give you a direct answer but I am using my Apple AirPod 4’s with both BraX3 and Pixel 8 Pro phones running iodéOS with no issue over Bluetooth (also Plantronics Headphones and a little Sony XB12 Speaker too)… So the airpods (and some Sony devices) can work with them, FWIW.
Have you tried unpairing these devices to everything else and then restarting the phone? Some other device in the vicinity may be interfering with the pairing.
I had the same issue with bose headphones. I coild connect to everything else, to the point that i’d drive past cars and all their bluetooth devices popped up on the phone.
I had to download the bose app from aurora and use that to get them paired. I then deleted the app and its worked ever since.
OMG IT WORKED - however it took three tries first normal with app no go then followed a different way still within the app ended up holding the power button for seven seconds got the pairing led light to flash red and blue the second time with this it worked both times the Brax3 showed the headphones however it took a second try. - SOOOOO happy Thanks Sparkie !
Hey thanks much _ see my reply to sparkie - got them paired. Woooo Hoooo
Hey thanks much Got them paired using the Sony app
Good work! Many a foible with this phone, but we get there in the end :slightly_smiling_face:
