Brax Tech Store
I/m confused about the Brax Tech Stores. When I go here;BraX3 – BraX3 store, I can see all Brax Tech offers; phone,case,charger and screen protection. But, if I go here; https://www.braxtech.net/, I can only see the phone offer. Is both sites legit? was the BraX3 – BraX3 store down for awhile? I couldn’t get there from my bookmarks, dns server not connecting.
It’s the same website - you can tell by the domain. Unfortunately the BraxTech team seem a bit weak on the web development & management side so there’s a very garbled presence (incl. a test store and the 2 links you sent). Just make sure you use:
This is the one @plamen has shared a couple of times.
But note the navigation is a bit broken there - if you go into the phone page you can’t easily get back to that main ‘collection’ page (doesn’t seem to be any ‘back’ navigation) and some internal links don’t work…
I think the Shopify site was a bit rushed so might not be complete and/or there are multiple instances with different subdomains or such…
Thanks for your help
Note - if you are on this tore and you use the ‘quick add to cart’ option when you hover over the phone it will add it to the shopify cart there; but if you click on the link and go to the actual BraX3 phone page, and try to add it instead it has a link back to pre-order at Indiegogo.
Pretty sure that’s wrong. All 3 accessories quick add and main product page links both add things to the Shopify cart.
So if purchasing the BraX3 there I think you should use the quick add to cart function on the page linked above; and not the Indiegogo pre-order button on the main product page.
I’ve mentioned this to @plamen - as I presume it’s an error and got overlooked when shopify site went live…
So, how do I get my Dec 4 order to the correct place…I ordered through Indigogo
contact [email protected]
