Brax3 Data Transfer Rate
Intriguing observation (for me) regarding Brax3 data transfer rate.
So I backed up my Brax3 using Seedvault which created a 31 GB file in internal memory. I wanted to back it up to a flash drive. So I used a flash drive that I had laying around and it took !! 4 hours !! to transfer the Seedvault file/folder. So I decided to buy a new flash drive which is rated up to 400 Mbps. The Brax3 USB C port is version 2.0. According to the internet it is rated at up to 480 Mbps. The result was astonishing. With the new flash drive it only took 30 minutes to transfer the same file. WOW… I can live with that. But 4 hours was just too much. Guess it is always good to upgrade even flash drives.
That’s about 150Mbps, you can probably get much more connecting to the computer even for a mechanical hard disk.
