Brax3 holster (add'l required characters)
The Brax3 in its provided protective sleeve fits very nicely into this holster. The holster rides a bit high for my flabby waist. Obviously it wont be worn on the Vicky’s Secret runway… but for old pharts like myself it seems to be a good solution.
Looks like a good option. Thanks for posting it up. Do you have a rugged case and do you think it’d still fit?
Yes, repeat: it fits nicely into the holster wearing its “rugged case” from the fine folks who originally sent me the phone.
Thanks then. The rugged case is obvioulsly larger than the case that came with the phone as standard, so just wanted to check before i order one
I ordered two of these. Thank you. Did you know you can thread your belt through the backstrap so the holster rides horizontally, allowing for a more natural flow of flabby bellies?
