Brax3 NFC issues
After the iodeOS update from 7.5 to 7.6 the NFC no longer turns on
Any work a rounds?
Update: reset the phone back to the original and re-updated the phone to 7.6 and it works again.
I have the same problem, NFC activation is greyed out with iodéOS 7.6-20260623-brax3.
In a dialogue with chat.mistral.ai, here is the information we have found about the issue, and hope it can help in solving the problem:
Problem: NFC Greyed Out / Cannot Enable on BraX3 with iodéOS 7.6 (Kernel/HAL Issue)
Device:
  • Model: Braxtech BraX3
  • OS: iodéOS 7.6 (official, not beta)
  • Build Date: 20260623
  • Android Version: 16
Issue:
  • NFC is greyed out in Settings > Connected devices > NFC and cannot be enabled.
  • No hardware switch or error message is shown.
Steps to Reproduce:
  1. Open Settings > Connected devices > NFC.
  2. Observe that the NFC toggle is greyed out and cannot be turned on.
  3. Reboot the phone: NFC remains greyed out.
Technical Details (ADB Outputs):
  • NFC HAL Status:
    adb shell dumpsys -l | grep -i nfc
    # Output: nfc
  • NFC Hardware Node:
    adb shell ls -l /dev/nfc*
    # Output: ls: /dev/nfc*: No such file or directory
  • NFC Service Property:
    adb shell getprop | grep -i nfc
    # Output: [init.svc.nfc_hal_service]: [running]
  • NFC set-enabled Command:
    adb shell cmd nfc set-enabled 1
    # Output: Exception: java.lang.SecurityException: Uid 2000 does not have access to set-enabled nfc command
  • NFC Service State:
    adb shell dumpsys nfc | head -20
    # Output:
    mState=turning on
    mAlwaysOnState=off
    mScreenState=OFF_LOCKED
    mIsSecureNfcEnabled=false
    mIsReaderOptionEnabled=true
    mIsAlwaysOnSupported=false
    SnoopLogMode=FILTERED
    VendorDebugEnabled=false
    mPowerSavingState=1
    mIsObserveModeSupported=false
    mIsObserveModeEnabled=false
    listenTech=0xf
    pollTech=0x2f
    mTechMask: 0
    mEnableLPD: true
    mEnableReader: false
    mEnableHostRouting: false
Analysis:
  • The NFC HAL service is running (init.svc.nfc_hal_service: [running]), but the NFC hardware node (/dev/nfc*) is missing.
  • dumpsys nfc shows mState=turning on, indicating the service is trying to enable NFC but fails due to the missing hardware node.
  • The kernel driver for NFC is not loaded or NFC is disabled in the device tree for this iodéOS 7.6 build.
What I’ve Tried:
  • Rebooting the phone.
  • Enabling NFC via ADB (adb shell settings put global nfc_enabled 1).
  • Checking for a hardware switch in the bootloader (no NFC-related messages found).
  • Running adb shell cmd nfc set-enabled 1 (fails with SecurityException).
Expected Behavior: NFC toggle should be clickable and functional, as it was in previous iodéOS versions (e.g., 7.3).
Additional Context:
  • NFC is said to have worked on earlier iodéOS versions (e.g., 7.3) for other BraX3 users.
  • No hardware modifications or root access on this device.
  • Not willing to factory reset or unlock bootloader (to avoid data loss).
Questions for the Community/Devs:
  1. Is NFC disabled in the kernel or device tree for iodéOS 7.6 on BraX3?
  2. If so, is this intentional, or is it a bug?
  3. Are there any workarounds (e.g., a patch, downgrade, or ADB command) to re-enable NFC without wiping the device?
  4. Is a fix planned for future updates?
Final Note: This appears to be a ROM/kernel-level issue rather than a hardware fault. Any guidance or confirmation from the devs would be greatly appreciated!
Not sure if this helps but I am on the 7.6 beta and NFC works. 7.6-20260610-brax3.
My NFC turns on. No way to test if it works. I always update the beta version. So far it hasn’t been a bad thing.
No probs over here in the South Pacific region with the NFC activation toggle after the recent 7.6 update.
Thanks for the reply… I reset the phone to the original and updated the phone back to 7.6 version and it works again.
Has anyone else had this NFC issue? Is this a one-off or is it affecting more than one user?
I have the same problem, after upgrading to 7.6.
If I nagivate to connected devices and connection preferences the NFC is set to off and greyed out.
Is there another way to enable it? Can it be regulated from a different security setting?
Also suffering this issue. NFC toggle greyed out. Rebooted but no dice.
Thank you for your feedback on this. We’ve identified the issue. A fix is being developed and tested at the moment. We expect to release an OS fix very soon.
issue also over here, so its a bug, I would love a quickfix
I’ve never understood how some devices can have a bug and other ones don’t. Programming is so weird.
Story of my life right here with a SIP phone system we’re running.
Today’s update has fixed this for me, thankyou :slight_smile:
Yes! NFC toggling works.
Great you got it fixed quickly - thanks.
awsome, iodéOS 7.7 works, thanks
Is iodéOS 7.6 here…
I’m on 7.6
