Brax3 not compatible witth US Mobile Dark Star (AT&T)
Brax3 will not work on US Mobile’s Dark Star system, which is their MVNO name for AT&T.
The phone can send and receive calls and SMS, but no data. “Mobile data” was toggled “on” and the phone did indicate it was connected to 5G/LTE.
The US Mobile rep explained, “Basically you should have certain Bands and certain network features in your device for it to work on our network. The device had the bands but not all Network features were available due to that your texts and calls were working but not your data.” I asked for more detailed information, but the rep would not provide any.
I put a Mint Mobile SIM in the Brax3 and it works flawlessly.
Been using USM/DarkStar with Brax3 for several months. (beta test)
iodeOS does not read the pSIM properly; once corrected - everyting be alllright !
That’s great news, since I would prefer to stay with USM.
Will that be fixed with a pending iodeOS update, or is there something I need to do on my end?
Agree, USM’s Dark Star plans are very economical/great value.
I’m not sure why iodeOS can’t read the AT&T MVNOs by default; a minor annoyance.
Correct the first two fields of the APN and save.
From what you say, most likely the BRAX3 is not reading the SIM correctly and is not routing to the APN of the MVNO but to that of the main operator, which probably blocks usage for MVNO customers. It should be enough to configure a new APN with the MVNO’s data and have it selected as the default. Here in Spain, it’s simpler because the operators and MVNOs that operate on a network share the APN, and they assign network priorities by MSISDN and IMSI.
Best regards.
no, it’s iodeOS
the BraX3 factory rom (LunarOS) reads the pSIM correctly. Confirmed during beta testing.
Correcting the first two fields in the APN worked… thank you!
very welcome.. enjoy your BraX3 on Dark Star .. ; )
Please mark the post with the correct APNs as the solution so others will find it.
I had not realized that US Mobile (Dark Star - ATT) is working, their help a few weeks back indicated only their Light Speed (TMobile) network would work.
As AT&T themselves won’t register the device, this is worth promoting for users that need an AT&T compatible option.
Thank you reminding me to mark the solution.
USM also tried to steer me to Light Speed. I’m grateful for tuxvip’s solution.
For Iode team, some screenshots from LunarOS for comparison.
Dark Star shows as carrier (LunarOS), not AT&T (iodeOS).
i corrected the first 2 lines, changing to Dark Star and ereseller, but still no data
Ugh… sorry it doesn’t work for you.
My friend’s phone, also on US Mobile Dark Star, has “ereseller” entered in both fields. I can’t imagine that would make any difference since the first field is a user defined name (I believe), but maybe it’s worth trying.
i just got mine to work. here are the settings:Name:
Dark Star
APN:
ereseller
MMSC:
http://mmsc.mobile.att.net
MMS Proxy:
proxy.mobile.att.net
MMS Port:
80
MCC:
310
MNC:
410 (280 if the APN does not save)
APN Type:
default,supl,mms,fota
APN Protocol:
IPv4/IPv6
4
Leave any unlisted fields blank. Tap Save or ✓.
5
Ensure that the new APN is selected and confirm if your APN is
Dark Star: Android APN Setup
1
Go to Settings > Connections / Network & Internet > Mobile Networks / Cellular Networks > Access Point Names. Some phones may have this option under:
Settings > Network & Internet > Mobile Network > Advanced > Access Point Names
Settings > Mobile Network > Access Point Names
2
Tap on + Add or the Menu icon (three dots) and select New APN.
3
Enter the following details:
Name:
Dark Star
APN:
ereseller
MMSC:
MMS Proxy:
MMS Port:
80
MCC:
310
MNC:
APN Type:
APN Protocol:
IPv4/IPv6
4
5
Ensure that the new APN is selected and confirm if your APN is saved.
the above post regarding settings for usmobile, i pasted the instructions twice accidentally.
