Brax3 vs mSpy, Phonsee, FlexiSpy SPYWARE
How does Brax3 deal with these Spyware?
What if one of these Spyware was able to enter your Phone, What can a Brax3 Phone do?
In terms of prevention, the BraX3 deals with them the same way a consumer smartphone like Samsung, Pixel will. If you install the app and give it access, it will execute.
In terms of detection, you can use the network traffic analyzer to help you identify that your phone is leaking data. You can basically see the connections your phone makes, to which servers and the amount of data being sent.
Thank you for the Reply
