Cant make calls over wifi I can receive calls and can send/recive sms
Hi can anyone help me get this sorted ? I can receive calls and can send/receive sms over wifi but I can’t Cant make calls over wifi. Wifi calling is on, is there anything I’ve missed
Probably APN settings, SMS and MMS have different access points, find the correct ones on your carrier’s website and go to Android Settings > About phone and enter them.
I thought the APN settings would have been ok since I can receive calls over wifi
Check the settings and contact the carrier, you may be missing something, maybe there is a recommended app for the calls.
There is an open bug about wifi calls, when unable to connect to cell service, on like when in Airplane Mode. It may be related. It’s an upstream bug with Lineage, and so I think Iode is waiting on the fix to roll down for that.
I’ve contacted the carrier and all settings are correct for wifi calling so it is a issue with iode
I placed a link to the bug in my last response, so you could follow, if desired.
Hi followed the info in the link still no outgoing calls over wifi
Hi all this has been fixed with iodéOS 7.0 wifi calling works now for making calls
