Connecting Brax3 to ethernet
Is it possible to connect Brax3 to the ethernet cable?
I would expect any USB-C Ethernet adapter that’s intended to work with Android would work just fine, though I haven’t personally tested any so I may just be hopelessly optimistic about such things.
Thanks, I am guessing that the android Drivers have been removed to allow connection to ethernet. I have the adapter, but nothing happens.
You likely still need to change the USB permissions once connected? Have you tried different USB permissions?
I just tried it with a USB-C adapter: no problems, it connects immediately, no specific permissions needed.
