Disable SIM slots/Cameras?
How to toggle disable the SIM slots? How to toggle disable Cameras? I am trying to disable the hardware, (not the App).
I am able to disable (toggle) microphone, and sensors.
Any help?
Thanks
Im still on brax2, under Developer options, quick developer tile options, there is a sensors off button which can be added to home screen drop down menu. Prob something similar on brax3. Cheers
Thanks for responding, I got (enabled) the sensors toggle, I was/am hoping for SIM and Camera toggles like those for WiFi, Bluetooth, etc.
For SIM the best you can do is go to Network & internet > SIMS (your sim) and toggle off there. I don’t know of a way to disable the camera. May I suggest the “sledge hammer” approach of using a sticker? :slight_smile:
THANKS, I didn’t see the SIM tab until you mentioned it. That serves my purpose for SIMs. I see that you have to have a SIM inserted and disable airplane mode, or the option is greyed out. I am used to the tape option for Cameras. I can/have disabled the Camera App, and that seems to work.
Thanks for the fast response.
The sensors off will disable camera, you can open the camera but it won’t take a picture.
Thanks, I wasn’t aware of the camera function.. is there a list of all the sensors affected?
Don’t think there is, but fingerprint sensor will stop too, use caution.
