Ok, I might just be overlooking it, but I’m trying to disable the lock screen Pin “feature”. I mean, I can input the Pin each time I pick up my phone but I’d rather just disable that requirement. Any idea how to do this? I’ve searched both here and on the phones settings but haven’t found the option….
I’ve not tried this myself but the following looks to be the path you need;
Go to settings, privacy and security, device unlock, screen lock pin, enter pin, click none and then delete. (I press cancel at the last step so I cannot verify 100% that is what you are looking for.)
That did it! Thanks so much!!
You’re welcome.
