SMS are working good, but for some of it I sometimes receive it twice, …even ×5 times or more.
SMS client is just the default one, no particular tweek.
Nobody else facing this annoying fact?
Are you coming from an iPhone?
FWIW I’ve experienced this many times for random periods over the years here, pretty sure it’s a telco provider issue… it’s not a handset or phone OS one.
The network here in NZ that used to be notorious for this happening every time they changed something with their servers or network infrastructure. Sometimes I’d get the same message 4 times over a 12 hour period and so on…
If it’s the same thing then it’s transient and issues will just ‘go away’ in a few hours or a day or a few days…
No. Regular Android.
Ok.
What has changed is I now use an eSIM. 2×SIM → SIM + eSIM.
Telco issue with eSIM maybe.
Thanks
iphones never made me do that.
Hi @pizzalinux1
Sometimes you can have similar issues if you are switching from iPhone to Android and don’t deregister imessage.
I did not know that. Thank you very much!
You’re welcome. We are all here to share & learn.
