Emoticons in Fossify?
I just received my BRAX3 and have been using it for 3 or 4 days. Will the Fossify Message app ever offer the ability to react to received messages or insert emoticons? Is this an option that can be easily added for someone who isn’t tech savvy?
Thanks
You would need to ask Fossify about those I’m guessing, as they maintain the app.
What is Astro description?
Fossify is the developers who created the messaging app you asked about. They are the ones to ask about adding any features or future plans. Braxtech has no control over that applications features
Maybe try FUTO keyboard, also grab the voice input module.
Hi,
Thanks for your replies. I found a functional solution that allows me to use emoticons. It’s the app called Fossify Keyboard Beta.
I hope this helps someone.
The Heliboard keyboard in Iode supports adding dictionaries. You might find an emoticon dictionary to add, that would work. I have not tried it.
Just as an aside I noticed the Fossify Keyboard doesn’t support the auto-suggestions/spelling corrections like Heliboard does (along the top of the keyboard) - at least not yet anyway?
Also doesn’t seem you can remove the default Heliboard even if you have another keyboard installed like Fossify - I presume because it’s essential component of the base OS?
