Been trying to finish the updates from F-Driod but every app dies before finishing downloading… Just in case, I turned off VPN and make sure my screen stays alive for 30 min. The worse one is the Iode Browser, it being a large download…
If you are using Carrier data, it is probably throttling as the file size grows. Can you connect via WIFI to do the updates, or are you already on WIIF?
