I’ve been having issues sending pictures via text message. Often getting “not sent. Touch to retry”. Tapping doesn’t do anything, messages not sent. The pictures are being sent to an iPhone. I have the resize MMS images set to 1MB (though I don’t personally care about it).
Who is your cell provider?
Which messaging app are you using?
Is it just to one person or different people?
Is it just to iPhone or Android users also?
I have Mint, using the default messaging app on the Brax3. I think it’s happened to multiple people, but it’s absolutely happening to one specific person who is using iPhone on Verizon.
I confirmed it’s an iPhone issue. Can text pictures to android.
That wouldn’t be a Brax3 phone issue. Possible APN or other mint issue. Here are a couple things that I have found
https://www.mintmobile.com/help/how-to-configure-android-settings/
My phone suddenly started having this issue. It will not send images all of the sudden to any kind of phone to people i have never had issue with before, android or iphone, it doesnt matter. It stopped sending images to anyone and it flashes an error code.
My phone suddenly started having this issue. It will not send images all of the sudden to any kind of phone to people i have never had issue with before, android or iphone, it doesnt matter. It stopped sending images to anyone and it flashes an error code. It started doing this last week. I have restarted multiple times, deleted apps, nothing helps
I use QUIK SMS from F-Droid, & it fixed my issues
Who is your carrier? Trying to use T-Mobile through Patriot mobile not having much luck with text messaging. Nothing showing to setup MMS packets for texting and pics . Tried f- droid quik sms still not working
Red Pocket using ATT lines. I think you can also get T-Mobile lines also? Good Luck
