Has anyone found a case that fits the Brax3
Has anyone found a case that fits the Brax3 from another vendor or Amazon?
@DonChevo502 This is going to be very challenging.
You can use the following site to potentially find other smartphones of the same size as the Brax3. I have not tried that but it is possible you may find some that are close enough. The real challenge is finding one of those that also has the same size rear camera opening as the Brax3, in the exact same place on the back. If by some miracle you do find such a phone, then you can simply try to order a case for that phone and try it on the Brax3. Of course, don’t forget to post your findings here and tell us if that case actually fits!
https://www.gsmarena.com/search.php3?
It only have me 1 hit and the camera opening is way off: Gionee K30 Pro - Specifications
I have a 3D printer and have printed cases for Iphone with TPU in the past. I don’t have the knowhow to design a CAD file for the Brax phone and then converter it to printable file. Maybe someone in this forum does and creates one.
@DonChevo502 Maybe they will.
The Brax team is pretty open about these things though. For example, they released this 3D model of the phone itself:
https://sketchfab.com/3d-models/brax3-2a512bc6c1b143878153644cdb563fbc
@plamen Is it possible to release the design files for the case that you sell for the Brax3? Perhaps someone could use that as a starting point to create a CAD file to 3D-print their own case?
Well, today by pure coincidence i was talki g with someone and noticed their phone was 99% close to the Brax, they let me look at it and test the case out on my Brax and fit was 99%on track. The finger print hole was partially covering the button , but nothing a razor blade couldn’t fix
Oppo A3 CPH 2669
I am going to order this case and try, i will update.
Check this thread - I have bought the one @rik suggested as a backup to the BraX Rugged Case, but haven’t tried it in the phone yet…
Note the pic in the post isn’t the same as the case on the link, it’s the one in the link with the oval camera lenses opening that’s the right one (at least that’s the one I bought)…
Sounds like a cool initiative to release CAD files of accessories.
Releasing a complete 3D model of the BraX3 has been a huge pain in the rear as I’ve had to get so many approvals from different supply chain partners in the process.
Phone case should be easier though. I’m taking a note to address it with manufacturing.
