There are many issues that I have. This is the most pressing- how do I get this to resize? It is not the obv arrow as it either goes to circle or square. Thanks
Below, sorry
Below, sorry
It seems that you have somehow enabled floating keyboard. The easiest fix should be to Storage of the keyboard app (HeliBoard) so it resets its settings to default. You can do that via: Settings > Apps > See all apps > HeliBoard > Storage & cache > Clear storage.
Let us know if that worked for you.
Also do not hesitate to share any other issues you’re experiencing. We will be happy to help.
Thank you! I cleared and now it works.
Having issues w my group chats. People that were my contacts that I brought from Iphone now do not show up as named contacts. Many times there’s a color palette next to the number & when I start to add the info it will auto fill. Using QUIK
I was using Spam Blocker and several contacts I could not see their texts. I would have to look in the spam to find their text. Where it would say contact. I deleted spam blocker about a week ago> now I get too much spam. There were way to many choices. Suggestion for an easy set and go for spam blocking? I know just enough to get into things that I can’t find my way out of! Thanks!
Long press the comma / (sometimes) Slash button and hit the 6 dot symbol that looks like the one at the bottom right on small keyboard
