Home security systems, are they safe
Hi, tried a search didn’t find anything. Is it safe to run a home security system/cameras apps on the Brax phone? Using Blink on the iphone want to use it on the Brax. Or if one can use/sign in on a web version is that the safe way? Thanks
no one have any experience or knowledge?
Well I’d say,rule of thumb is no they aren’t - if it goes through a cloud server likely has compromises of some sort depending on who it is…
Having said that I have my camera system installed, but its in work profile under Shelter and frozen unless I specifically need to look at the cameras or footage (I have a DVR physically onsite in my home but currently connected to the manufacturer’s ‘cloud’ for offsite access).
I’m not currently using my alarm system’s remote control app - its by an Australian company and has about 30 different trackers in it!
