How can I Dim Brax3 Phone Screen Further?
I turned off adaptive brightness, have Brightness level to 0% and enabled Extra Dim feature.
How can I Dim Brax3 Phone Brightness level Further?
There is an “extra dim” setting under “Accessibility”, but it doesn’t do much more than what you have done.
I know on some Samsung phones you can totally turn off the backlight, but I don’t know of any way to do it on a Brax3.
Are you on Special Ops or working in a photographic darkroom? :exclamation_question_mark:
I’m trying not to draw attention at work; listening to video podcasts.
Can you not just set the video podcast to run, and then use the fingerprint button to close down the screen? Most ‘aftermarket’ apps for you tube, Spotify etc would allow this
Go to the auto parts store and see if you can buy a small section of window tinting material to place over the screen. If you can find a shop that specializes in window tints, they probably would give you a scrap large enough to suit your purpose.
